- Joined
- Nov 7, 2006
- Messages
- 6,948
- Name
- Doug
DAmnit i think i have seen them around where is they???
								There NEEDS to be a gate valve between the water supply and the Dwyer..get rid of the stupid Dema proportioning valve!Nate The Great said:http://mikeysboard.com/forum/viewtopic.php?f=1&t=22068&p=245136&hilit=+photobucket+chem+draw#p245136
That's the way Les told me to set mines up. The stupid Dema valve froze closed and wouldn't fill my mix tank. I have a manual float now, and still need to hook mines up. I'm only missing the 0-5 dwyer meter.
ACE said:What are the Blue bulb things coming out the pumps on Judsons?
bob vawter said:There NEEDS to be a gate valve between the water supply and the Dwyer..get rid of the stupid Dema proportioning valve!
NOOOO...dgardner said:bob vawter said:There NEEDS to be a gate valve between the water supply and the Dwyer..get rid of the stupid Dema proportioning valve!
Bob, with your setup, if the wand isn't keyed, where does the bypass from the regulator go? Back to the water box? Does that mean the chems keep recycling and dilution gets stronger and stronger until the wand is re-keyed? Jus tryin to understand your setup.
