where are the pics of "judsons" chem draw???
DAmnit i think i have seen them around where is they???
Nate The Great said:
http://mikeysboard.com/forum/viewtopic.php?f=1&t=22068&p=245136&hilit=+photobucket+chem+draw#p245136
That's the way Les told me to set mines up. The stupid Dema valve froze closed and wouldn't fill my mix tank. I have a manual float now, and still need to hook mines up. I'm only missing the 0-5 dwyer meter.
There NEEDS to be a gate valve between the water supply and the Dwyer..get rid of the stupid Dema proportioning valve!
is that the draw side??
come on man am stoopid
also whats the little hose going up fer
Hoody
Steven Hoodlebrink
Years of Experience
20
Don't worry Bawb, when I get back to Utah I'll be sure to give Doug a swift kick in the arse for you! :mrgreen:
ACE
Mike Hughes
What are the Blue bulb things coming out the pumps on Judsons?
dgardner
Dan Gardner
Bob, with your setup, if the wand isn't keyed, where does the bypass from the regulator go? Back to the water box? Does that mean the chems keep recycling and dilution gets stronger and stronger until the wand is re-keyed? Jus tryin to understand your setup.
NOOOO...
not at all...the chem feed only feeds on the supply of the pump.....the water don go nowhere when unkeyed....i acn't believe some of the things you guys put up wit....
EDUCATION is the KEY for buying a machine that yotr future depends on.....
anyone buying a machine should call me for questions to ask BEFORE buying......
