Which counter top spinner?
Acp
Bjorn Marshall
this is another really good one, no chem injection and no vac but if you pre spray the grout and keep a small 1 gal shop vac for sucking up removed caulking anyways then it doesnt matter. Higher psi and slightly hotter
using these is much better when replacing caulking because you dont have to worry about a wet shower or drying it
Bjorn, I urge real caution with vapor steam on carpet. I turned a gum spot into s carpetfro once. It resembled an oversize merkin.
Reactions: Acp
Acp
Bjorn Marshall
whoa lol, ya you have to be really careful but as long as you have the right microfiber over the end of the tool your using its pretty safe. same with upholstery.
you need the thick white microfibers for upholstery or spotting carpet
the best use for them is definitely tight spots on counter tops and showers
