- Joined
- Aug 19, 2013
- Messages
- 7,044
- Name
- John Stewart
debris ..
True.. but this time there was no debris.debris....and then gravity.
Why is the valve at the top of the wand?
Usually it's just the o ring in the trigger valve. Replace and grease. Problem solved usually. $.05 part.I replaced the trigger valve- Problem solved.![]()
Do you know What size are the O-rings are?Usually it's just the o ring in the trigger valve. Replace and grease. Problem solved usually. $.05 part.
It depends on the style of valve. You can order extra o rings from your local distributor or sometimes pick them up at the hardware store. Some places will sell you an o ring kit with many sizes. Just match the old one to the new one.Do you know What size are the O-rings are?
If the valve was at the manifold and just a cable to the grip....like a brake cable.because our arms aren't long enough to reach the wand head ....
