A van with 2 -12VDC batteries is still 12 VDC. The batteries are set up in parallel to double the amps for starting (diesel motors need more starting amps since their compression is so high). The voltage is still 12 VDC.
In my gasoline truckmount, which has it's own 12VDC battery, I used a welding cable to connect it in parallel to the van battery under the hood, so I have double the amps for starting the truckmount, and double amps for starting the van. This setup will greatly increase the life of both batteries, since you will have about 1400 cold cranking amps total.
I also have a 1500 watt 12VDC to 110VAC inverter that can supply 15 amps of 110VAC power if I ever need it. Our LP heater and APO use 110VAC (2.5 amps total), so the inverter gives us the AC we need to operate those components. The Honda 24 HP motor charges both batteries when running. The van alternator charges both batteries when running. The truckmount's charging system runs the inverter while we are cleaning.
Both batteries have been in there for years without needing to change them out.
I also carry an 800 AMP jumpstarter just in case
http://www.northerntool.com/shop/to...2357?cm_mmc=Housefile-_-SHIPPED-_-1206-_-CONF.
No one likes to be stranded. ...lol
