Al said:
Thanks Harper, what speed is the buffer you use?
They are standard 175's...
I would not recommend a "high Speed" burnisher ...if you are not experienced...
If you will notice in the photo's...there is a white haze on the floor.. :!:
If you allow the Neutral detergent to haze..."very similar to waxing a car"
The impurities..are easier to remove with the DRY bonnets... :wink:
This way the bonnets...DO NOT..gum-up... :idea:
Ps Do small areas at a time...The same way you wax a car..roof,hood,trunk,
quarter panels etc....etc... :!: If you have ever put wax on an ENTIRE car &
then tried to remove it all at once..
You know what I mean.. :wink:
