Goomer
I came across several staircases of wool or wool blend today. I am not sure if they were 100 percent wool, because I plucked several loose fibers to check, and they had a smooth stiff hard acrylic feel to them. I was sure of the wool content as soon as I presprayed them and got a whiff
In remembering most information here about cleaning w2w wool, I did remember that it was the older Jute backing that was the thing to worry about regarding shrinkage, and that if it was newer carpet, which it obviously is, just don't over wet/heat/ph, and there should be no problem, but it seems that there was some shrinkage. Right after a very light prespray and low psi/heat cleaning, I noticed that the sides of the stairs were pulling away from the walls. Upon closer inspection I found that all the landings were tacked to the wall on all 4 sides, but on the stair treads, only one side of the tread was tacked down, and the side up against the wall was not fastened in any way, only cut flush to the wall, and it was this unfastened side that was showing a gap.I checked the lower uncleaned dry staircase to confirm, and again, not fasted in anyway against the wall.
The end result was this:
So my questions are:
Is there a valid reason it was installed this way??
Is there anything I could have done to avoid it??
Will it relax and return to normal when dry??
