- Joined
- Oct 6, 2006
- Messages
- 117,345
Our world famous prep letter tells them that we will be vacuuming
A neck brace and Butt Plug?To get out this.
That my friends is revenge. This past summer I may have put a bra that I found during college dorm turns into a fellow carpet cleaners waste tank. It was hilarious watching him from the next building over trying to figure out why his waste tank would not drain. His revenge was better. Sometimes mine would drain and sometimes it would not. This is what being friends with local carpet cleaners will get you.Explain please
It’s my parking lotYou always dump in the parking lot?
Doesn't matter who's it is, still running off to the storm drains.It’s my parking lot
you have a special catchment or something? where does the dirty water go?Sorry smarty. Not here.
Here, most parking lots just drain into the storm drains. If people see you dumping they will be on the phone to the municipality. Fortunately, the complaint process is so complicated, most give up.Parking lots here for the most part use retention ponds with no drainage to anywhere. It Just sits there and evaporates. Or there are Leeds parking lots that absorb and hold all runoff. Only roads utilize storm drains that go to waterways. There are always exceptions and I do pay attention. My parking lot has a grass run off to a retention pond full of four eyed frogswoth no residue. And my retention pond has the fastest dry of any one around. Thanks to VLM. And of course I filter the solids out of my drainage. Except for when I have to shove a stick up the drain pipe in order to get foam toys out of the way.
Ya but you break everything so there’s that!Dysons overheat and switch off. I don't like that. If I want to melt down my vacuum I should have that option available to me.
