Yup, I'm doin' it!
Russ T.
Russ Terhaar
Nobody's home, huge vacant resi job, freezing cold...will use door drape. How you like me now?
The Clean Machine
GCCLee
C. Lee
You Panzie ! Put yur dang coat on ya hoodlum.
Jeebus : )
George Valliant
It's 20 degrees right now here in Albuquerque. It's crazy cold! At the moment i'm warming up the truck getting ready to go knock out a couple houses. How cold is it outside where you are at?
Russ T.
Russ Terhaar
A lot of guys would NEVER park in a garage while cleaning. I'm one of the almost never kind of guys.
The Clean Machine
so when that door drape doesn't keep the carbon monoxide out of the home.............how long before somebody finds you?
Two employees of one of my customers died running a truck mount in the garage of the empty house they were cleaning.
Maybe I'm missing something, and I don't mean to lecture, but I will never forget hearing about that. I have had several other customers get sick doing that too.
Scary stuff, I'd think twice about it.
At the very least use a fan to blow exhaust away from the truck and out the garage door. Use a Carbon Monoxide detector.....that is if you are willing to trust your life to a $15.00 detector. :eekk:
Russ T.
Russ Terhaar
I am seriously going to move the truck i think. It's a 3 car garage. I can open all doors and I am using a door drape. What do you think?
The Clean Machine
Thanks for showing us you took it out Russ. The two employees that died were a husband and wife team working for the cleaner I knew.
I lost another customer who was sitting inside of his truck with the unit running to warm up on a very cold day because he got wet from the water supply hose.
Everyone be careful out there.
Reactions: Russ T.
Vivers
Bill
Well I wouldn't do that but then again it doesn't get that cold here. This morning low however was 33° here in Southern California
Does the carbon monoxide just hit ya upside the head and pow?
Some of the survivors who talked to me about it said they felt tired, and just thought they needed to take a break. Some went outside and other people saw how red their faces were and told them something was wrong, others had terrible headaches and figured out the problem in time.
Reactions: GCCLee
It was 8-degree when I came to work. It's 31 now warmest day in a week.
C&S
Scott
ive gotten sick from it before, you get tired, and get a headache. I wasn't even parked inside, but the van was parked close enough to the door that the air that gets pulled in had exhaust in it. 15 min was all it took to make me sick. so if you experience this go outside, shut off machine, sit down, take deep breaths, see dr if you can.
Reactions: Art Kelley
Actually I think many of us are exposed to more carbon monoxide poisoning than we imagine. I've set off CO detectors a couple of times when I could have sworn there was more than adequate ventilation to dissapate the exhaust outside the door.
Personally knew 3 who died.
I have set a few off...parked in a drive way and the exhaust it pointing toward the side of the house and a breeze starts to blow it up in the garage.....and straight into the home.....
