- Joined
- Oct 6, 2006
- Messages
- 116,871
not yet. Erik is afraid to send me one after what Rob pulled.
GeneMiller said:I love the zipper and the concept. I've been waiting for something like it to come out. It just makes sense to clean both directions. My problem is it looks like the spray bar is in the middle which means it won't clean next to the wall like a wand will. I don't want to pull out both tools.
gene
Mikey P said:Erik
Is the main head cast or CNC'd?
Eric Valentine said:GeneMiller said:I love the zipper and the concept. I've been waiting for something like it to come out. It just makes sense to clean both directions. My problem is it looks like the spray bar is in the middle which means it won't clean next to the wall like a wand will. I don't want to pull out both tools.
gene
The spray is directed at the front glide:
:wink:Brian R[color=#0000FF][color=#0000FF][color=#0000FF][/color][/color][/color] said:Why is it open on the side? Why not?
What does it weigh? 29 lbs- 35lbs. w/ weights
How easy is it to work on? Brian, I think you could even work on it !gotcha!
What guarantees do you have? 3 mo- 1 year, depending on what component
Is it adjustable for us tall guys? Short guys? It has a non-fixed handle, size doesn't matter, but that's not what she says
What size guy was it made for? any size
What is some problems that we might encounter with it? getting use to something different
What is the top PSI? 1,500
Do you make a carrying case or some kind of "box" to store it in a van from job to job? Not yet, strap it in and put a piece of rubber under it.Where is Carmen Sandiego? Who knows.
What's your profit margin with that price? NOYB shiteatinggrin
How easy is it to clean? Windex and a rag
Where's my baby momma? Which one?
Where can we demo it? at Connections in Las Vegas
Can we pimp it out or is it pimped? For a price, I can engrave Priority on it
Laminar airflow? yes
Feather trigger? Or something similar? Precision Fluid Control Valve, very easy on the hand
Can you take the weight off and put back on fairly easily? 30 Seconds
Can I get one in Mary Kay pink? Any color you want with a pre order and a price.
Can a dumbass operate it? Your welcome Bob. Yes
NobleCarpetCleaners said:If the jets are threading into aluminum I would take a step back before delivering them that way. Two things, dissimilar corrosion and a rapid wearing of the aluminum threads. If you installed a stainless threaded insert then you have extended the life tremendously.
:wink:Erik said:Does that mean I should make the head out of Magnesium?
Aluminum and stainless steal go together very well, no it will not corrode.Brian R said:Erik said:Does that mean I should make the head out of Magnesium?
Hey, who cares if it's going to corrode and fall apart....I wanna know if it's going to steam up the house in front of the homeowner.![]()
Really, What about that whole side being open thing?
Erik said:Aluminum and stainless steal go together very well, no it will not corrode.Brian R said:Erik said:Does that mean I should make the head out of Magnesium?
The only part that is open is a little area on the top of the glide retainer.
The steam stays contained good under the head.
Does your wand steam up the house? yes.
lance said:Hey Eric, great job with the Jr.
I have been told by a user of the Zipper that resi carpet makes you work very hard to move it because of the pad.
Yes, this is true if the back wheels are not adjusted for padded carpet. The head acts as a snow plow, if the wheels are not adjusted down about 3/16". I have customers that use them primarly for residential and they leave the wheels adjusted just for padded carpet. It may take 5-10 minutes with a flat surface and an ICS magazine under the glides, so that the wheels are touching the flat surface.
How is the Jr. different? Less weight? Lower cg? or what?
