Zipper - Water Usage?
steamron
Ron
Comparing the Zipper Wand and the Zipper Spinner,
How much more water does the spinner use to the regular zipper?
The psi jump up when using the spinner, so I was wondering if anyone compared
the difference (not guessing).
Thanks
a five gallon bucket works best.
test your normal wand too...
the SS uses a LOT of water at 1000 psi
Erik
Erik
The SS is a 4 flow and puts out 1.5 Gpm. at 1,ooo Psi. It's equivalent to a 8 flow at 500 Psi.
Joey H
Joey H
In my experience i have found that i get much better dry times with my S.S. Models than i do with my standard zippers. I have a standard 15 inch setup at 12 flow and 2 Zipper S.S. models that are set at 4 flow and 6 flow. Im using less water when running the S.S.
The Zipper SS Super Spinner because you can clean faster a lot of times due to its agitation from the jets, I really think I take less water PER SQUARE FOOT than a lot of other tools.
Even the 12 flow Zipper Wand can haul the mail and take less per Sq foot.
Reactions: Joey H
