Mytee Escape Truckmount
rmarrow19
Like New condition! Very low hours. Truckmount is less than a month old. Comes on a cart. You can bring it in with you. It can be used to clean carpets, upholstery and hard surface. Call me for pricing. 804-297-9860
Items Included
Cart: contains two front 4″ locking casters & two rear 10″ wheels
3 Prong 30 amp dryer adaptor cord
4 Prong 30 amp dryer adaptor cord
Two 50′ 12/3 twist lock power cords
Chemical metering
5-quart Big Mouth Bottle
2″ x 2.5″ Cuff-Lynxâ?¢ reducer
2.5″ x 2.5″ swivel Cuff-Lynxâ?¢
Pump prime / vacuum tank wash-out hose
25' pump-out vacuum hose with cam lock connection
Also comes with 2 Circuit Hunter boxes. These boxes normally sell for $339 each
image.php
Reactions: TomKing
Fort Worth , Texas
The mytee escape has been out for years and unless I missed something haven't heard bad things about it.
Unlike those crappy prochem ti wands with the screwed in heads.
Anything you like to share about your experiences cleaning with the escape?
That's a true insult to anyone's intelligence. Although I don't think the ETM's fit that description. I have more issue with those posers that try to put off a portable as a TM. Its not and never will be!
Even IF it could reproduce similar numbers in cfm, lift and pressure...a cobbled mess of components does not make it a truck mount. Well, not one from any of the major manufacturers. :winky:
Bigger wheels! :winky:
Seriously it was designed to be moved, notwithstanding its weight. A refrigerator while moveable was not designed to be moved more than twice.
In when new and out when replaced
. :very_drunk:
Reactions: TomKing
rick imby
Montana
Rick
Richard---moved only twice? I don't want to see the linoleum under your fridge.... I doubt you wife would still be with you if your fridge had never been moved since you moved it into the house.
