The Wand Window...
TConway
Thomas Conway
How do you keep yours from cracking?
Marty,
I will send you some NEW windows, They should fit, you will need to put the slightest amount of silicone to the recessed area and put the new window in, I know it will work as I have done it on mine.
The new windows/heads have NO screws, I asked PMF to make it a press fit and they hit a home run, but they will work on the head you have too, and you can get rid of the 4 screws
Reactions: Steve Lawrence
Marty,
Don’t waste your time. Marty can’t see through the cataracts anyway.
back to the future of sight tubes .......
in the olden dayz, I discovered if you used foamy emulsifier and pre-sprays, carpet nectar that started up the tube dirty black became a nice light color foamy swill in no time ...musta been reeley clean huh...
Mow-rons
I had a sight tube when you were mosh pit'in with the other punkrock, pack following weirdos
Mullets, before mullets wuz cool :cool:
The issues were reliability related and failure.
Fixing was a problem and rivets through plexi glass for the win!
Benton KY USA
Clear pipes have been around since the early 1970's. I had several Steamex box extractors with 5' long acrylic wand tubes. Later, 1976, several Vibra Vac power heads with clear tubes similar to what the Zipper uses.
Reactions: vibra-vacster
