Bob Pruitt
Incorporating the industry’s first true water conservation system, it also can be inactive under a full vacuum load for as long as 40 minutes without dumping fresh water. That means you can move furniture or apply pre-conditioners without running to shut off your machine, and your fresh water and recovery tanks need to be filled and emptied less often.
Your hot water is used on the job, not dumped into the recovery tank.
From Hydramaster regarding the Titan 575.
http://www.hydramaster.com/Products/Truckmounts/Titan575.aspx
