and if you don't like the O2 prespray why not?
simply cause it's not a very effective pre-spray.
that's why nearly all the Judfan faithful use S&G now..cause it actually works
How much you want to bet Marty won't be able to figure out he can enter this raffle 40 times..
I think gun smoke has fried your brain.
[LEFT said:Yea i know you're Auburn guy, but ya'll look alike to me
[/LEFT]
I guess I like the fact that I can trust what's IN the S&G more than what's in the Flex.
Reeko, I seriously think that by NOW you should have made a decision on your chemical line and should stick with it. Changing chemicals every month or two when you are running crews should be avoided, since I know your school system is no better than ours is, and half your employees either can't, or won't read the label directions.
Let them learn the products you use and get used to the mixing directions, and let them get in the groove.
And Ron, don't listen to him. If you seriously think you can't trust Bridgepoint over the ingredients in Flex, then you need to feel pressure to step up your game and get in the 21st century.
S&G w an after spray deodorizer.
O2 w Modifier
O2 Rinse
what's the "modifier" for, Chris?
You Modify it to boost the PH and give it a lil kick
I know...cause it doesn't work so great on soiled carpet unless you boost it
and that was my point
Has anyone compared The Flex with Cobbs Powermax? I've used Powermax and like it a lot. Unless it's a huge leap in effectiveness I don't see myself switching considering Flex is pound for pound TWICE the $$$ as Powermax.
We compare presprays by using a dollars worth of each product.
That is what you are paying for.
Try it yourself,
I am confident PowerMax will win.
Dave Gill has been using it for many years with very good results.
Larry
