After three days in the Nevada sun . . .
testing every large carpet wand and rotary extractor at the show . . .
I was disappointed at the performance of about half of them.
On Wednesday, we started with TM wands 14" to 16" on some very dirty medium-grade plush-pile nylon.
First out of the box was Westpack's 14" new Titanium Wand.
It needed more work, as it streaked the carpet badly.
Next, I tried the PMF 15" Titanium, but it also streaked the carpet.
On to the the veteran PC Titanium, but it caused obvious streaking as well.
The Butler 14" was also tested, but also showed streaks.
Finally, we tried the brand new 15" Zipper Wand which cleaned well & did not streak . . .
but did have quite a bit of water over-spraying on the left & right.
Then it was on to the rotaries . . .
First up was the Interlink "CX-15 Whirlwind" . . . which had a "turbo two-jet rotating spinner head" with a trailing Teflon glide to extract the water. The positive points were that it cleaned well and left the carpet with minimum moisture. The negative was the the clean circle it created at the start AND the end of the cleaning stroke. They were very obvious, & difficult to remove.
View attachment 5461 . Great Photo courtesy Jim Martin
Next, I tried the 15" RotaVac XL . . .
It cleaned the carpet well, and did not leave any streaks.
Also, as demoed by a young lady, was able to clean right up to the edge of the carpet.
The Hoss was up next and although it used the stock jets, cleaned well, and was smooth in operation.
RX-20 also did a good job of cleaning, but to me did not operate as smoothly as the rotaries above.
After seeing some of the poor performance . . .
I have to agree with Mikey . . .
more testing needs to be done for final products that we tested at the outdoor cleaning challenge .
When I went to the CRI testing seminar, they talked extensively about the new softer-hand carpets . . .
the denier per filament has dropped down to ~4 DPF . . .
This carpet is prone to streak more prominently than most of the carpet you are cleaning today.
The CRI also stated that a "Glide" is REQUIRED to operate a wide wand successfully on this new fine filament carpet.
Larry
P.S. Mikey did a very good job putting all pieces in place for the outdoor testing.
Larry
