Here's one angle to consider...
The amount of propane a system uses for heat is actually variable, depending upon how hot you like to run it, your flow rate (higher flow rate requires more BTU's since the GPM is more), the efficiency of the heater and even your wand keying habits. (The more you key / flush and go over an area more thoroughly, the more you will burn in a given amount of time...)
But...
For the sake of discussion, let's say you're burning 1 GPH of propane per hour of actual machine time. And you're working 40 hours a week. Out of that 40, your actual machine time is less than 40, due to travel time between jobs, setting up and breaking down, discussions with customers, etc. Your actual machine time will be more like 25 hours out of 40.
So, 4 weeks a month, equals 4 x 25 hours, or 100 hours a month.
100 hours x 1 GPH = 100 gallons of propane.
Propane is currently about $3.50 per gallon, so you're spending $350 per month, based upon the above figures.
12 months x $350 = $4,200 per year
For a typical exchanger to deliver the same temperature of 200 degrees, at a flow rate of 2 GPM, you'll spend $20,000 for that system. And, if you're like most owners, you'll keep that system for 4 years or less.
A propane system that delivers that kind of heat will typically cost you about $14,000 (a Dominator 2036 is $13,500). So, it will cost you $6,000 LESS up front than an exchanger system that can produce even similar heat.
Based upon the above, it will take you 1.4 years to recuperate the extra costs of that comparable heat exchange system based upon fuel usage alone.
The increased complexity of HX systems (all HX systems that deliver heat in the above- mentioned range have at least 2 exchangers and 2 sets of sensors, 2 sets of controls, etc...) results in increased maintenance requirements as well, which have to be considered... especially as the system gets older.
In my experience, at 2 years and further, maintenance requirements increase noticeably... And the increased requirements of the typical HX system really become a factor at that point.
