bob vawter
Grassy Knoller
i saw no metering system
Put on your glasses and look again.i saw no metering system
Me?I was talking to Lee today about this..
You have under 10k to spend..
You don't know hit about this sort of equipment..
you don't now if CCing is gonna work for you
so do you go.....
New Texas or Reliabuilt?
Used Prochem
Porty
VLM
Loan for new top shelf unit
06 Hydrmaster 450D
Correction... it's not the diesel, it's the regular gas engine... Same with the van. Change your opinion at all? I can probably get the van and TM for 8-9k.I wouldn't want a stinky chat 'n rattle diesel...truck or TM
and fuel is a buck-o-gallon more
I don't know if the Nick-o-Matic TM has improved from the ole dayz or not.
I suspect it's had to or Cobblet and Steam Brite wouldn't continue to private label them
for your intended purpose (limited use) the Nick-o-matic AND trailer set up seems like a better deal .
No addition insurance to pay on a van that sits most of the time.
and the trailer will have more room for hauling drying equipment
a 36 blower wound tight at 3400 rpm @15 hg will pull water plenty fine.
The only thing I'd be concerned about has been mentioned..
..can the unit be run dry for hours without damage to HX'er or pump.
a pump on/off clutch would be essential
and perhaps an exhaust diverter for HX'er
(but don't know if it hurts them to get "that" hot without water)
Even a 12 year old one with 1200 hours?I’d choose a HydraMaster over an ez any day
Not you in particularMe?
I’m certainly not new, have been cleaning for years, but VLM, and we do well.
I just need a TM for basement and an occasional flush after scrubbing with VLM. I don’t want to spend a lot because we won’t use the machine a lot.
Just saying I’m not new to this.
ohhhh... I new it was coming...not unless you do a lot of water damage .
Or intend to start cleaning carpets better as your primary biz model
Not at all... I enjoy the banter... I rarely take anything personally. I was just swinging back.don't take it personal, Chris
we're mostly a veteran journeymen lot here .
Most of us are familiar with and regularly use VLM methods too
albeit, not generally in residential ..too many kids, pets and upl
(VLM doesn't clean upl worth a chit)
I'm open-minded enough to accept that possibility.Yep own two Sprayborg Orbots and a Vibe, a long with 8 Cimex's.
Once you see how much easier HWE is with your TM, you'll reach for it first on all the dirty jobs...then in a year or two all the others. You'll still use the VLM on special need projects but a transition will take place as you have options and are not locked into a system.
Roll the pump belt offI’m trying to find out if that machine has the ability to turn off the pump, but info is difficult to find.
Thanks
I would go with the ez. Less complicated and easier to work on. Just remember for water damage, hook up as though you're cleaning carpets and let the pressure hose run wide open. Turn the Chem feed off or pull the feed hose out.Not at all... I enjoy the banter... I rarely take anything personally. I was just swinging back.
But... if you were me and thinking about adding a HWE truck and wanted to start cheap to see if it fits our model, would you go with an almost new EZ (2036) in a trailer or an old Hydramaster (2545) with relatively low hours that's been maintained in a van ready to roll?
I don't really understand what you mean by leaving the pressure hose run wide open... Don't I really want the pump to not run at all?I would go with the ez. Less complicated and easier to work on. Just remember for water damage, hook up as though you're cleaning carpets and let the pressure hose run wide open. Turn the Chem feed off or pull the feed hose out.
I've read lots of your stuff...There are certain times when VLM will be too time consuming and the carpet needs to be steam cleaned to .......remove all of that...............scampoo..................residue
What he means by that pump is that if it doesn't have a clutch to shut it off you will have to have it on to bleed off that pressure so it doesn't over heat the machine.
You must like assholes. We don't like your kind here.That Hog Jowl guy is also likable in a asshole kind of way...
This place is much better than some other place.
Thanks but I think I'm ready to try a TM just to see what's what.Again, I see where your coming from. I’m in a similar situation to you, I pull a trailer with a truckmount in it. No one can tell you exactly what’s best for you. You have to decide. I’m with all here about the heat exchanger, and clutch pump. You could always put a porty in the trailer just for basements
