- Oct 7, 2006
- 49,895
He better hope Bristors little buddy isn't there. It could be war.
If you need an extra run of hose it can be added. Not a problem. It comes stock with 25'.
I already have a back up.
It's called a C4.
If that unit ever needs a back up it will be a 200 psi two 3 stage porty that I can actually lift into my pick up truck.
Now if I were using a unit each and every job like Willy I don't know wtf I'd do..
I don't keep up with the latest and greatest ways to do a shitty job
Good to know on the pump Willy.
How does it handle being used three times a year?
Is there a specific way to store it so the seals last?
I'm thinking that it's positioned well to fill the commercial niche. What do you guys think? Configuration? Colors? Name? Price? Let me know what you think. I appreciate your feedback!
I wonder if it comes in other configurations. Like NO auto fill/ drain and no heat.
) that you don't "have" to use auto fill/auto dump to operate it.I wonder if it comes in other configurations. Like NO auto fill/ drain and no heat. You can almost always get hot water on the job and unless you can stick it in a janitor closet auto fill/ drain scares me about leaks. (OK I worry too much)
Go to Sandia's website, they have all different configurations, then slap a Vortex sticker on it and you have the latest and greatest High Performance portable
I have a Mytee unit with 2 3 stage vacs and a 200psi pump ( just get larger jets on the wand to increase flow to compensate for low pressure)
Unit can run on one cord with one vac if electricity is an issue or 2 cords and both 3 stage are operating
Only use it less than a dozen times a year, and it cost less than half the price
if I hadn't of gotten ass raped for over $3000 on that POS there probably would be no MB.
