- Oct 7, 2006
- 49,936
one hell of a unit Larry.
Any chance I can see or run one next month?
I am certain you'd be welcome at Nick's BBQ.
Can you dual wand consistently w/ the machine?
What type of heat will it sustain 2 wands @ #7.5 to #10 flow? We normally run 1 wand @ 400 psi, and 250-400 on the 360i (but we need to get the smaller jets for the 360i as it over wets the carpet too much).
Heat is not too much of a concern for us when using the 360i, but would be nice if the machine would be able handle two 360i's or 2 turbo hybrids w/ that blower/pump setup.
Is it possible that the pump can be upgraded to a higher gpm/psi for 2 turbo hybrids to work together and keep up w/ the required psi for residential tile cleaning? If so, which pump would you recommend?
