Shorty
- Nov 8, 2006
- 5,111
- Name
- Shorty Glanville
The ShearDry is not intended to be a tool that you can hold up in the air and spray without over spray or dripping. It is intended to clean upholstery without over spray or dripping and that is what exactly it does. The ShearDry has two water canals adjacent to the two vacuum slots that actually fill with water uniformly from the solution holes during cleaning. The water is then sucked across the fiber with a shearing action in an even flow with no over spray or dripping. Another advantage of this water delivery system is that you do not get the spray lines on the fabric like you do with the SS tool. In addition, the vacuum slot is closer to the nose and edge than the SS tool for closer corner and edge cleaning.
Thanks for that explanation Jeff, I had posted on another post asking you a question before I read this post.
