Willy P
- Oct 2, 2007
- 10,952
- Name
- Willy P
What pump? How many PSI?"Cat or Pumptec? What vacuum motor size? How many inches of lift? How many CFM? Onboard or inline heater? How many watts?Water capacity?Thermostat shutoff? How many poles on the switches? What size are the rear wheels? Guillotine dump valve or waste hose? Front or rear fill? How high?How many cords? How long? What gauge?
. 212 degrees at the tip- for how long? 30 seconds and then wait 5 minutes for it to reheat. I put the kleenrite 3250 watt heater inline with the Power Flite perfect heat exchangers and the internal 2000 watt heater- that kept up.
with a "heater". Don't go over 25 feet and double or triple the dry passes! Next time call me and I'll help you out...
about porty's?!?
