870 won't run
mwall2230
Tampa
Mike Wallace
It is about 3 decibels quieter than my thermal wave 5m. That's a huge difference. Mike can you take a picture of how you connected in your pump. Has to go in through the front so you don't bypass the pressure gauge. What pump are you using.
Gene
Gene I use the mytee truckmount transfer pump. It's held up better than any other I've used. http://r.ebay.com/Pj9Gdk
I ran the hose from the transfer pump through the forklift opening just under the water inlet on the front of the machine. I also used a 90 and ran my pressure hose through the same opening so all my hoses are hidden.
Boca Raton
I put a tee in the front and ran the line straight down. I wanted to run the pump through the pressure reducer and I didn't feel like taking it apart. I mounted the pump on the back wall of the tool box. Not sure the pump frame can handle it but that's were I put it. It's gonna take a pounding. I had a shurflo 5.7 extreme on my shelf. It's old but still works perfectly.
Gene
