B
If I had that unit I think I would be replacing that elbow with a stainless box and put a regular threaded inlet filter inside.
It's like pointing out a possible restriction on an early model Butler silencer. Bad taste.
I think you guys are just making a simple solution or maintenance issue more difficult.
It would seem, these suggested modifications would create more unnecessary components on a simple system.
It's a non issue, now that we are aware of this potential blockage.
Had a PC Legend in the shop today for low vacuum.
PC Engineer used an "aluminum nipple" for the large vac filter to thread onto.
It had corroded the threads to the point that it required destroying the vac filter with an air chisel,
to even turn the filter.
I'm hoping to avoid that. The adaptor I fabbed for the machine I am building is all stainless. I just recently got a second argon cylinder and regulator so I can properly back-purge the stainless. Huge improvement. Here's the filter - 11" long with 3" NPT connection:
couldnt you have put a single full size filter in and gotten the same or more surface area to pull air threw, sorry i was in manufacturing and i see these things. more surface area = less restriction.
Mike, is that how Les designs the C4 units? Or is that a modification you have done? I still don't like seeing that 90 and all those filters. But what do I know?
The C4 has an air chamber that comes up from the tank in order to slow the air down. No filters
So you added the filters? Correct?
