- Oct 7, 2006
- 49,892
Would it be expecting too much of you to stay on topic, Taco?
I want to feel confident, not scare people.
Talked took a local guy yesterday who had that mach12 wand.
Uses a White Magic 45 slide in and loves it.
By no means a hack.
Really looking forward to Saturday..
Loren, I use to work for a company in Denver that had that same Steamway Powermatic 2100 back in 1994. It had a kerosene burner. Even though they perform well, I don't like fuel fired burners. To much liability IMO
I first tried this Mach 12 in Vegas in September.
I need to use it more before coming to a conclusion but so far I'm loving it.
While it is a custom length for me, its very light, easy to toss around fully adjustable manifolds, secure two piece glide and believe it or not....
appeared to dry as well as the 2" wand I tested side by side.
with a 25 foot inch and a 1/2 whip..
, just working with my prototype right now. I have a list of things I want to try and accomplish with this wand. Will keep you all posted.Funny,Can you show us some drawings and or some sketches of the general idea so someone can knock it off as quickly as possible?
First you get a 2.5" tube that is ~4 ft. long (was that optional ?).
But then . . . you restrict it with a 1.5" x 5 ft. tube on the wand.
Should I run 2.5 to the wand in your opinion?First you get a 2.5" tube that is ~4 ft. long (was that optional ?).
No that stock set up was not optional.
Funny,
The prototype is working very well, I can just say I am very focused on the wand, Tim is trying to take all my input and make it come to reality. The prototype is bad azz.
I tried to clean without a glide the other day..the suck is so hard I can only pull....I put @ a 4" ripple into the center of the carpet as I was only able to pull and not push.
When I get it done it will be one of the best flowing, flushing, drying wands on the market.
I can say that even though it has that much suck, with my design I came up with...my WIFE can use it ONE HANDED....it is gonna blow your minds
I have been keeping Mikey in the loop of development as we move forward, he doen't know all the details but he has seen it in action.
And are you still going to clean stairs with your wand??The amount of airflow you can use to convey soil laden moisture from the carpet to the recovery tank is something that can be measured.
Your loyal followers from the days when you were the "bad boy who said horrible things, but was often right" on ICS are likely recoiling at your decision to get a mid range powered machine. That horror is compounded, likely, by their knowledge that you will also use a 1.5" whip hose and a 1.5" wand.
What can't be measured, and should be considered, is this:
Will the lack of "heavy hose and wand fatigue" allow you to make extra dry strokes? Conversely, are there hard working "big blower/big hose" devotees who, in their more seasoned ages, are becoming a bit more careless about those extra dry strokes?
I guess this is a convulted way of saying something I should say more simply:
"Let us know if using means of cleaning that are easier on you physically will allow you to do as good a job as you did in your days of using what was then called a "VAT" truck mount"
Winding a cord like that is called a Daisy chain and is the best way to wind 100' or more cord. Does not damage, twist or tangle. It does take a minute to make but well worth it when you unwind and your cord is not tangled.My new employee started winding cords that way last week and I was ....WTF!
