So I cleaned our own carpets
Zee
SoCal jungle
This morning I hit our carpets with a pump up sprayer filled with leftover EncapucleanO2... Scrubbed it with the CRB.... Followed that up with the truckmount and a 20 flow Greenhorn. (fresh water only)
Did my normal wanding strokes and dropped a couple of blowers here and there.
Took about 2 hours to do the job. (9-11)
Three bedrooms upstairs, stairs, livingroom hallway, master bedroom downstairs.
Went out to the mall for a Lego store run and to have lunch... (I did not have the blowers run while we were away)
And we've been playing around/laying around on these carpets with the new Legos etc since 3pm and I can tell you that it is truly dry.
Every time I do this, I'm always amazed at how this can be done so easily and there are still hacks out there that collect reviews like: "the carpet was soaking wet for 3days.."
Could I have done it faster? Yes....indeed.
But it's worth doing decent reduced speed dry strokes to really allow the water to get worked up through the fiber into the wand and save hours of drying time.
Zee
SoCal jungle
This is the type of loop carpet we have....and it keeps coming back to me how some of the companies out there only clean these carpets with bonnets and claim they can't be steam cleaned. Right Cole?
Rolling eyes...
Fook Zee, thats not carpet! :winky:
What is your humidity like there? I can see doing that here with a Zipper but you might as well triple drying time with just a wand.
Humidity is terrible here. :errf:
Reactions: TomKing
Zee
SoCal jungle
Around 45% when I was working. Maybe a little higher...
This is right now :
Zee
SoCal jungle
@Desk Jockey, Yes I did...
@Cleanworks not even close to that much water. I didn't check but I'm in doubt about the Cat pump on the truckmount even being capable of that much.
I'd say the Cat pump is no more than 3-4gpm
WHOA WHOA WHOA , it was pet job and she lied about the dry times.
According the the Pumptec nozzle performance chart, it you are using a 20 flow at 500 psi, you are putting out 7.07 gpm. If your pump is not capable of that performance, it is probably cavitating and damaging the pump. 10 flow at 500 psi is 3.54 gpm, 6 flow is 2.12
Zee
SoCal jungle
What hose size?
It doesn't matter what the hose size, it still has to be compressed to come out the nozzles. If you used 3/8 hose, it would still be the same as 1/4 inch.
Zee
SoCal jungle
I'll check it with a bucket.... When I have time...and when I feel like I'm using too much water and too high flow for everyone's liking even though they never tried it. :lol:
It's not a matter of liking it or not, if your are exceeding the capacity of your pump, you may want to downsize to your max capacity. When you are beside your truck, look at your pressure gauge and trigger the wand. Your gauge will drop to the pressure that the pump can actually provide. Adjust the regulator to that pressure so that you are not seeing a large drop. A drop of up 50 psi is normal
My wand is set at 9.5flow. That means I can't go over 700psi on my carpet wand, because my water pump produces up to 4gpm. Am I correct at reading that chart?
Victoria, BC
Bill Soukoreff
It is not just the jets and pump that determine flow. It is also the wand valve and hose size. Compare a Westpak soft touch (Greenhorn) and the Zipper/Butler Paraplate valve. The later allows more flow.
Zee
SoCal jungle
What kind of a frooking carpet cleaner has time, let alone the will, to clean his own carpet?
Must be a European thing :winky:
It is actually a surprising nice feel knowing that I cleaned these carpets and they look good, feel good. So every time I do it, I'm thinking: I'd totally pay for this service if I knew it was going to be such an outstanding over the top quality job. :lol: :lol: :lol:
best way to find out is to stand beside your truck, trigger the wand, look at the pressure gauge and turn up the pressure until it won't climb anymore. That will tell you if you are exceeding your pumps flow capacity. If you find you can't maintain the pressure you want with a certain size flow, reduce it gradually, until your happy with it. Large flow is great as long as you have the vacuum recovery for it.
