Paid it off last month, this month a crack in the engine... Uggggggg.
Yep, literally paid it off last month.
Other day I notice my pos Kohler is leaking more than normal. Have had the rear gasket repaired twice already over the last 4 years. It's always been a very slow leak. Like a half quart for 6 months.
Go out to take some photos and get some help and notice why... Is this not a crack?!
As you can see the two pieces come together over right on the frame rail. Seems to me this could very easily be cause by the back cover constantly banging the rail, especially on starting???
Maybe when I take it to my local disty(jd) to get flogged I should have them put some wasters or something under there? It's obviously caused by over tightening (them) or banging the rail.
Anyways, any idea what the back part of a 20 hp kohler command pro is called? I've searched(rear engine cover, etc.)the net, not finding any helpful results...
Any possibilities this is something a large disty(jd) would have in stock???
Happy Sunday!
Can you use ms paint to put an arrow where you think the leak is?
Where's Bawb when you need him? You may want to reinstall the engine with shock absorbing rubber washers to dampen the vibration. What unit is that?
Reactions: Spurlington
This is the part I'll need.
Thank you, Fred!:rockon: Looks like it's either 26 or 126.
Apparently it's called a "CLOSURE PLATE ASSEMBLY (SERVICE) $402.25"..... Wow, four hundred bucks before the disty. Plus, new belts, engine removal, shop charges(lol), etc... Ouch.
It's an older 370.
[parsehtml]<iframe style="width:120px;height:240px;" marginwidth="0" marginheight="0" scrolling="no" frameborder="0" src="//ws-na.amazon-adsystem.com/widgets/q?ServiceVersion=20070822&OneJS=1&Operation=GetAdHtml&MarketPlace=US&source=ss&ref=as_ss_li_til&ad_type=product_link&tracking_id=swsfcc-20&marketplace=amazon&region=US&placement=B0006O1ICE&asins=B0006O1ICE&linkId=f01dc798080dcb786b524f62d0f463c2&show_border=true&link_opens_in_new_window=true"></iframe>[/parsehtml]
I'm no mechanic but it appears to be cracking at all of the stress points where the bolts go through. It could be the bolts are being over torqued. I would have your dealer look at it first before you do anything. Depending on the hours on it, you may want to just buy a new engine. You want to find out what's causing it before spending that much.
Although Kohler motors ARE an acceptable motor for certain circumstances. ...lawn mowers and maybe generators....it IS NOT designed for an 8 hour day ..six days a week. ....JUS NOT!!!
If you want to be a professional. ...you have to step up and buy professional equipment made for the job yor doing.
If I were young and starting a bidness. ..I'd buy a Butler
God I can't believe I SED that.....
But I would...
So it looks like it never made it back for a warranty repair or they didn't think it was a problem at the time and now it's too late.
Reactions: jcooper
I don't know what you had done and when but this failure point was obvious back in 2012:
was it under warranty then?
did you put all that nellows there or was that a dealer repair?
Reactions: Bob Pruitt
dgardner
Dan Gardner
Jerry, are you sure oil is leaking from that spot? it looks more like a casting flaw (that doesn't go all the way through) than a crack...
dgardner
Dan Gardner
Cracks almost never go in a straight line, and usually have sharp, crisp edges, like this:
Or this:
Yes, it was under warranty then, JD removed the engine and fixed with new gasket, belts, etc.
You must have a photographic memory Fred.
No kidding, it's appreciated! The first time it leaked(12) they tightened it, second time new gasket. I believe...
jcooper said: ↑
And help me to understand how it could be banging on the frame rail if the motor is solidly bolted down and can't move.
Not sure, Dave. Just seems possible from vibration. The space between the rail and engine cover is nil.
but it didn't need a new gasket......it needed a closure plate :D
Is that the same spot? It looks like it continued to "open"
dgardner
Dan Gardner
It looks like the original leak continues to do so - notice the oil wetness radiating from the old crack/leak and nothing from the new "leak":
Reactions: jcooper
I don't know hard to see on my phone...............
but I would think it more likely to be leaking at the gasket interface between the two bolts which may have more clearance now that the "new leak" has opened up more
Yea, appears to be same spot.
At least this week is slow, as long as I can get through 3 jobs tomorrow. Should be able to get it in Tuesday. Should I run out and get some jb weld?
The equivalent of 2-4 payments and your rolling another 3-4 years??
Get it fixed, good luck.
Hopefully you have a back up
Hopefully you can get it done fast.
Reactions: jcooper
I would not repair if motor has over 1500 hours, I would replace the engine which will take less than 3-4 hours to do.
While motor is out replace all high pressure hoses( very easy while motor is out), rebuild/replace regulator and clean up the frame in all places not normally accessible but accessible now that motor is out.
Motor should be no more than 1450 belts another 40 hoses 160 for the main hoses in stainless covered Teflon with jic fittings.
1650 if you do it, or 1650 plus labor to have it done is still not bad and then the engine won't start nickel and dimming you like coils, stator,head gaskets, cover gaskets cam stripping out, starter, inverter any of the bearings, valves or completely crack the block.
By the time the disty is done with me, I'm sure a new motor is going to be like 2-2500$ installed, at least... :eekk:
It's been "nickel and dimming" sense the day I got it!
