used water box
Jamesh921
James
I'll try to make that happen tomorrow. What exactly do you want to see?
A
Able 1
I want to hear more then see.. Under load in the van would be great! Video across the head (where the spark plugs are)..
A
Able 1
It is amazing to me that all the heat exchanger are fine.. That water box is jacked up!!
Jamesh921
James
OK I have video but can't figure out how to post it. I can post pics but can't figure out how to post the video
A
Able 1
I think you have to upload it to YouTube or whatever other sites do it.. Then copy and paste here.
We should get Fred to revamp the site so we can down load videos directly. That'll make Marty happy
Reactions: Able 1
Jamesh921
James
Is that flat rectangle filter in the tank clean?
CLEAN AS A WHISTLE as is the lint filter. I talked to a mechanic @ PCS today and he said that (if the filters weren't kept clean in the past) the heat exchanger may be blocked by lint/debris. I'm going to pull and check them tomorrow.
I don't know how to post to YouTube yet. I work all the time and have no time to learn techy stuff. However, if you want to send me an email or cell # in a private msg, I can send you the video.
A
Able 1
Sent..
A
Able 1
These blowers are tough!! If there is crap in there, SLOWLY (It's not a water pump) run water by hose though the blower.. Don't think that your problem.
A
Able 1
If you do run water through the blower let it run for a while after and this is the only time I would spray wd40 in the cup..
You sure your vacuum gauge is working?
I'm looking to buy a gauge I can test at the end of a hose run to see where I'm at
One with the rubber 1/2 ball thing shows lift.
You can buy a vac gauge at Acklands/Grainger or other supply. I drilled a hole in some aluminum plate and put a gasket around it. Cheaper than buying a premade tester
Jamesh921
James
I don't know what to do here Able. I tried texting you the video from my iPhone but it said the video was too large to send. So, I tried sending it to you in an email, but apparently yahoo mail can't handle a 1:51 video. It says that I have to upload it to iCloud or Google. I have neither. :(
A
Able 1
No, I didn't get it..
How does the engine sound (worthless question for a guy that hasn't ran it for hours)?
If he doesn't get it send it to me 6618866806 I have an iPhone and can make a YouTube video and post it
Reactions: Able 1
I was out all day and my son used up all our data sorry it took so ling
Jamesh921
James
Could be belt slippage to on the blower
That's what I'm going to check next. I pulled the heat exchangers today to check for blockage but they were OK.
I also think the rpms are too low so I'm going to adjust the linkage to speed it up as well.
