used water box
Able 1
Keith
Keith,
I took your advice
The hg went straight to 15.
So, there's got to be a blockage on the intake side of the blower. I've removed and checked the hoses, cleaned the lint basket and filter and looked all thru the waste tank and I can't find a blockage anywhere.
It's a leak maybe your new lid gasket is loosing some suction that's where my 405 starts to fail.
http://www.jondon.com/gasket-waste-tank-lid.html
Make sure your using the right one and there's no gaps. 99% of the time it's the lid gasket.
Jamesh921
James
You're right Sam. The lid gasket (although new) was leaking. I took some Seran Wrap and went around the entire machine, holding it up to any place that might be leaking air. The waste tank lid was sucking it in so I know it's leaking some. Can't say whether that is the "entire" problem, but it's certainly contributing. I ordered another new gasket and will be installing it tomorrow. I'll post the results when it's done.
Jamesh921
James
By the way if you idle down the machine you would hear the leak.
I heard the leak in the beginning -that's why I replaced it. Can't hear any leaks now, but using the Seran Wrap confirmed that it's leaking so that' why I ordered a new one.
Make sure you scrap all the old crap and glue off use marine goop or if anybody else has a good suggestion use that.
I took your advice when you posted about replacing the lid seal. It made a huge difference for me.
It was leaking so much I didn't hear it at first. But, as I was working on it I had a small leak that screamed until I got it sealed up.
Jamesh921
James
OK so I got the new lid gasket on. Sure enough the new one I put on 6 weeks ago was leaking. So, now it's pulling 14.5 hg. If there's a good side to all this extra crap I had to got thru, it's that it has helped me learn the machine a lot better. So, I appreciate all the help you guys offered up.
