Orek Orbitor for residential...
E
EDS
Does post bonneting after HWE with a encap solution make that much of a difference? I have access to a floor machine 175 but have no desire to be lugging it around with me.
Would the Orek surfice? Is there any other brands that make a similar product that has a small foot print?
It's too light.... Agitating stairs is where it really shines......
Reactions: EDS
encapman
Rick Gelinas
I recently used an Oreck Orbiter as a freebie to help out some elderly friends from the congregation. I didn't want to run across town and get the work truck, so I tossed the Orbiter into my car and cleaned their carpet. It turned out decent. Took a while - longer than it should've. And it was decent looking when it was done. But I don't think I'd ever want to use that on more than a one off approach - it just took way too long.
I use it in home to encap area rugs on hardwood....
Reactions: EDS
E
EDS
What would be your suggestion for something compact for residential after HWE.
Post padding should not really be needed on resi hwe if you use a RE.
meep bop schmoops smizits.
Reactions: EDS
E
EDS
Damn... its just for those rat nasties that in occasionally come across...but a RE should be on the truck...fml
E
EDS
Maybe some encap on bonnet could have done better after hwe....same with the stairs...
Goomer
Frank Mendo
POS, idc what @Goomer said, things a turd...
:lol:
LOL........As a niche tool for agitating and padding smaller areas and stairs, the Orbiter ROCKS.
There is no other.
An Oreck is EXACTLY what you want.
E
EDS
I have....was think for post hwe but we went over this before. You forgot. Age is catching up with you....
I saw a guy who put a short handle on an oreck just to scrub stairs. Looked pretty good
