Nate The Great
- Mar 29, 2008
- 9,756
- Name
- Nate W.
I do, Matt. And your momma loves you. That's all you need.
A face only a mother could love?!?
That's weird. I've heard other cleanco guys say the same, the 56 didn't feel any better than the 47. But I know WM ran the 1200 HV with the 56 set at 18-20 hg. I have to believe that butler stayed with the 47 spinning fast and at 15hg for a reason. Maybe the 47 is the limit for a blend of CFM,lift and belt longevity.No.
10 inches of lift
So what RPM should I run my 56 at for best performance? I'm at about 1500 now.
The Momma jokes have Come back! Just like Marty's Momma told me to Come Back after lunch.And your momma loves me.
Waterhead.
thats engine RPM, what do you have the blower spinning at?Guess I'll leave it alone.
No clueTh
Do you have a tack on you're control panel? You should....No clue
Yes that's at 1500Do you have a tack on you're control panel? You should....
My Compact 47 'recommends 2850.... I'm running @ 3150...... Keep it clean, overservice it.... Bump it up, a little... 1750.....??????Yes that's at 1500
It got LOUD.My Compact 47 'recommends 2850.... I'm running @ 3150...... Keep it clean, overservice it.... Bump it up, a little... 1750.....??????
I know....3150 engine is crazy rpm for a direct drive. WAY to high.
The blower is spinning @ 3150.... The engine is spinning @ 2400.....3150 engine is crazy rpm for a direct drive. WAY to high.
I've checked the blower RPM, and checked engine RMP..... 2400.....The blower is spinning @ 3150.... The engine is spinning @ 2400.....
I will find out tomorrow what my 47 is capable of......Max rpm for a 56 is 2850
I was wondering at what RPM do you get the max airflow.
I will be insulating the solution hose for 60' from the truck.......I will find out tomorrow what my 47 is capable of......
I wonder about your numbers too. Coming from a Bane skews expectationsI may have to get some gages someday. It's fun making tweaks and seeing the difference at the wand. It makes me wonder what the numbers really are.
Bite me!I wonder about your numbers too. Coming from a Bane skews expectations
Ever had a Cleanco Lee?I had two, so I've already been bitten.
No. I do have a WM pro 2000, similar to Steve's machine.E
