Good service
J
JS41035
No.
10 inches of lift
That's weird. I've heard other cleanco guys say the same, the 56 didn't feel any better than the 47. But I know WM ran the 1200 HV with the 56 set at 18-20 hg. I have to believe that butler stayed with the 47 spinning fast and at 15hg for a reason. Maybe the 47 is the limit for a blend of CFM,lift and belt longevity.
So what RPM should I run my 56 at for best performance? I'm at about 1500 now.
Bc
I also had an experience with good service today. I walked into a custom fab shop, and had them make me up a 2 1/2" split into 2, 2" Y..... I said I needed it fast, the owner pulled one of his guys off what he was doing, and had it done in 45 min...... Stainless..... That's service!
My blower heat exchanger is shot. I'm thinking of removing it temporarily and replacing the silencer. Want to see if it helps it breathe better.
The blower needs replacing too. Lots of hours and has a knock sometimes.
Max rpm for a 56 is 2850
I was wondering at what RPM do you get the max airflow.
I may have to get some gages someday. It's fun making tweaks and seeing the difference at the wand. It makes me wonder what the numbers really are.
