- Feb 7, 2012
- 19
- Name
- Kevin
Hi! I'm an "experienced amateur" at this carpet cleaning stuff, and a "porty hack" to boot (No choice in being same here...). I've been at my facility for 8 1/2 years now, and as such I pick up bits and pieces of knowledge from various sources, especially from this site here, although there a good amount of humor to be found here there's also a huge volume of collected knowledge on same as well...
My question is as follows: On commercial nylon carpet is it OK to use a "175 floor machine" and a red pad to work in pre spray with? I seem to remember several threads on here saying it was an appropriate procedure to use for same...I have a nasty traffic lane area with embedded grunge on same, on Friday I attacked it with boosted Saiger's Sauce 1, worked same in with the red pad/floor machine combo, then extracted the area with my porty (U.S. Products PEX 500) using JonDon's "Confidence" in the extraction water (following Mr. Saiger's advice to use an emulsifying agent in the machine water for grungy areas).
The results were nothing short of spectacular (sadly no pics here...they frown upon photos being taken of their facility for some reason), all the grunge was removed and the carpet looked 1000 times better than it did before...Sadly the night person, whom we refer to as the "Mad Russian", took one look at my work and proceeded to dump all over same, claiming I was ruining the carpet fibers (This from a person who uses a cloth rag to work out spots by rubbing them!)
If I'm wrong here about using a red pad then please inform me of a better way to do this...As I stated before, the results were nothing short of amazing here...Thanks for any info!
