Prochem Performer Rebuild ( Pics, Detailed)
KevinD
Kevin Dumas
Blowers are very expensive especially if you get them through our industry.
Last one I bought was through a Gardner Denver Distributor and saved a bundle.
dwdiesel.com
Reactions: Austin Willoughby
Austin Willoughby
Just an update of where I'm at on this build
Jim Williams
Jim Williams
One option you could go with is rerouting the blower exhaust so that it no longer goes through the heat exchanger and getting a Little Giant heater. You would increase the suction and have years of trouble free, very hot heat. I'm getting ready to do a similar rebuild on a 2004 White Magic Commander. It still runs great but is leaking from every major component. I stripped the machine down years ago to bare bones. When I replaced the engine I got rid of pretty much all electrical except for the engine ignition switch. The more you can simplify that baby the better.
Austin Willoughby
I was considering a little giant but don't wanna spend 1500 dollars I figure if the heat exchanger goes out ill bypass it at that point and get a little giant or possibly upgrade at that point. I'd like to simplify it some bit don't know that there's really much that can be removed on the electrical side.
Very adjustable, usually 3 presets on the throttle control.
I’m just curious at how fast that blower is spinning. Because if it has room to increase, maybe he could get a smaller pulley on the blower to make it suck better
Austin Willoughby
Ill let ya know this afternoon but I think its 3600rpm on high I'll need to read a little more on it tho.
Austin Willoughby
Looks like it is done to me. Time for a new van and machine?
Nahhh not even close it ran without skipping beat just really doesn't look professional plus had a few oil leaks very small ones. I figured wth if I'm gonna pull it apart to change the gaskets I might as well do the whole thing while I'm there. I think the guy who sold it to me however felt like you new van and machine so I got a steal and I've already made my money back on it :rockon::rockon:
Austin Willoughby
Here's a video of when I first got the machine and posted it on T-M-F. Correction no leak in the heat exchanger I don't believe. That was an overload of fuel running down the cylinder walls coming out the exhaust also do not need a throttle regulator its fine lol. Also I sound very country so enjoy lol
You sound normal to me. I’m always wanting to get on the defense when I’m talking to a west coaster because their accent sounds so rude
Austin Willoughby
Ha yea I guess that's true we do have the southern hospitality after all :icon_cool:
The exhaust is a non issue. Condensation from the heat exchanger has it heats up.
As you mentioned the vacuum is supposed to bite down like that under a load. Non issue.
Sounds strong. She will run for many years.
Austin Willoughby
Absolutely agree I did good with this one I just wanna take it back to its hay day plus I think I'll feel more confident and professional knowing I've got a like new machine and redecorated trailer. I'm excited!
If you can afford it, now would be a great time to replace all hoses and belts. Check solution pump, vacuum pump, governor on the Nissan.
I Like the collapsible hose idea for your dump water. I might rig something like that for when I need to dump when my APO isn't working or am too lazy to run the APO hose.
