Don’t use stripper. Use special prep pads. Square scrub, but not exclusively square. Use 13, 17, 20, and even on the auto scrubbers. Rarely use stripper.:.)You dont strip or you use a square scrub?
I thought pressure washing was not good for windows.pressure wash and squeegee.
Welcome to the 21st century![]()
I don't know but I use a 20 degree tip and about 500 psi just getting it wet pretty much.I thought pressure washing was not good for windows.
Already been down the nano rabbit hole, the polishing rabbit hole, and lots of other holesspensive is the key word on anything. Just like mega dollars for tile and grout cleaning, if it ain’t practical, they won’t use it long term. That’s what they hire me for. Keep it looking good at a reasonable amount of money, #please
That is is cool. That would be soft pressure cleaning. That works, did you do the all the exterior as well?I don't know but I use a 20 degree tip and about 500 psi just getting it wet pretty much.
I'm no pro just what I'm doing.
Just the exterior.That is is cool. That would be soft pressure cleaning. That works, did you do the all the exterior as well?
Did you have a lot of cloudy areas or streaks?
besides Sams issuesstreaks can also be caused through using old product or mixing new and old, some finishes can offgas if left sitting around and the solids dont seem to blend as well.
My terminology or explanation is possibly wrong but I don't like using old product or mixing new and old
yep like my post reads its offgassing causes itCome on you’ve streaked once or twice?
