This shower is kicking my butt!
Swani
I've tried Viper Peroxybright that has a ph of 2-3 and a high alkaline tile and grout cleaner. Scrubbed the grout lines with a stainless steel brush rinsed at 1000 and 1500 psi. But the grout stays dark. 20180814_134759.jpg 20180814_135108.jpg 20180814_134759.jpg
You scrubbed it with a steel brush and blasted it at 1500 psi... Not much else you can do.
Really, other than different products - it is what it is.
I'd imagine when dry(completely) it looked better. Most do...
Reactions: Living The Dream
Swani
I know Mikey says to never color seal a shower but the home owner really wants it to look more uniform and brighter.
btw, how is it in this day and age, you are finding it possible to take such shitty pictures?
Hold the camera very steady when you hit the "button" and dont move it the nano second after.
J
JohnHawkP
I had a tricky one yesterday.
I used strong neat bleach and a quick agitation.
I checked it 45 minutes later and another quick agitation and it all came off and looked fine.
The bleach probably won't work as well on the walls because it won't stay in the grout lines.
The bleach will degrade the latex in the grout and is not recommended unless other solutions have been tried.
Swani
when I enlarge and zoom in on those photos it looks like there may have been a consumer color seal product applied at some point
I was thinking the same thing but have never ran into it before. They really want it to look better. Do you think using grout perfect would be a terrible idea? I know you've said in the past to never color seal a shower but I don't think they have much to lose at this point.
Mike, assuming the customer would pay, could he ream out the grout lines a bit with a diamond blade on a multitool, then regrout with SGA?
not ideal but can you run a grout rake over it lightly to remove the colour?
I've done that to a shower the owner didn't want to pay for regrouting I couldn't get even looking
this saved my azz on a floor we used the wrong color grout on :icon_redface:
https://www.homedepot.com/p/Milwaukee-5-in-Grout-Rake-Reciprocating-Saw-Blade-49-00-5450/202525956
faster than a multi-tool grout blade and no less easy to use/control
thank God it was caught in time and only had 150ft of 12x24 tiles to redo
note, to use the above tool, you need a short stroke sawsall (the smaller one hand ones) not full size/longer stroke ones.
You'll have better control
.L.T.A.
Reactions: Old Coastie
