I have some wisdom for truckmount owners.......
Noble Carpet Cleaners
on the 370 tank after 10-15 jobs there is for me some scattered lint just under the basket shelf in the first section of the tank. Washes away with a garden hose.
After 15 years of cleaning out all the stupid inline filters and baskets and losing suction when they get full...I'm doing the same thing you are and I"m not looking back. Steady suction is better than a clean waste tank
Reactions: Matt B
allclean_nj1
Bob Johnson
1st place in the almost vintage modified class of AquaTechs for 2018. 2019 version in the works. I am swapping out the 100 gallon waste tank for the 210 all day tank this winter.
Both HP and vac hoses run out of the back doors Bawb. Valves seen below are the waste clean-out and fresh water supply/drain.
The grey hose is for vac tank emptying.
View attachment 88022View attachment 88023View attachment 88024View attachment 88025
Are those yellow door stops ??? were did u get them please
These are the best ones I've ever used. Kaivac sells them.
Reactions: steve_64
til some knucklehead pushes on a wood 'n jamb door the wrong way and rips a hinge loose :eekk:
Haven't had it happen between the two buildings YET. Larry would it snap the plastic first or pull the hinge?
If I send you one can make a video of it damaging your door. For instructional purposes...of course. šŸ˜‰
Hey, how do you like the steel roof(house)?
We need a new roof at some point. Steel might hide the waviness of this pos.
sassyotto
Paul
I like the idea of a smaller waste tank with an auto pumpout. Has worked for me.
The big waste tank only takes up valuable space
How long is the driveshaft.
And how many tubes in each HX
That's only cuz you ......DON'T LISTEN!!!
I have so much to say but am just too tired to say it. It's been a kick ass week for me and so far the best February on record.
Sir Isaac Newton is standing on the shoulders of a giant.
He says "So, how do I get down off you?"
The giant says "You don't get down off me."
"You get down off a goose."
Confucious say, No need to squeeze ass cheeks when you already farted.
FB7777
The most interesting contribution to this thread
Rob Grady
Rob Grady
The metal roofing has worked out great.
Fred nailed it on the wheel chocks and door stoppers.
You can purchase the A in Zapper at he hardware store.
The heat x'RS are a Cleanco set.
The drives haft is a two piece design used on AquaTechs. The forward section attaches to the engine, the intermediate shaft has a u-joint and sliding feature that connects to the blower/water pump base unit.
