Orbot failure.
Welshmalc
Malcolm
started cleaning tiles then suddenly the Machine started spinning at high speed instead of oscillating and died . Machine only been used 25/30 times over 2year period. Any ideas what would cause this ?
Welshmalc
Malcolm
Only issues I've had before are screws wearing into tile and grout brush which plate.
T
thecleaningdude
Could be the shaft. Have you contacted your distributor or HOS direct yet?
Welshmalc
Malcolm
Not yet but I will. because it's running very fast I'm guessing the part that makes the machine oscillate as separated from the shaft so that's why it speeds up .....I guess
