Welshmalc
started cleaning tiles then suddenly the Machine started spinning at high speed instead of oscillating and died . Machine only been used 25/30 times over 2year period. Any ideas what would cause this ?
nope just on for couple of minutes,just started to spin extremely fast then died .
Never heard of such a thing. Did the motor over heat or burn up?
No hos orbit orbitalAny loose or missing bolts?
Is this a Vibe?
Not yet but I will. because it's running very fast I'm guessing the part that makes the machine oscillate as separated from the shaft so that's why it speeds up .....I guessCould be the shaft. Have you contacted your distributor or HOS direct yet?
