icleancarpetz
- Mar 7, 2015
- 1,710
- Name
- Rafael Samson
so hot dirt runs the other way...literally melting dirt away...
Direct drive
Propane
Diesel
Direct drive
Propane
Diesel
DieselDirect drive
Propane
Diesel
IDK... but this was done by a DD... doing tile 2 days ago... touched the steel...View attachment 101328
I would think Propane little giant heater.I dont think you'd say that if you'd used a fuel burner... the reason you've got a 650 is to imitate what every fuel burner doesHeat exchanger direct drive or slide in
because you’re not cleaning kitchen vent hoods. You’re cleaning carpet.
yeah the burner that came on my oxley could put out insane heat if you wanted it tohad a TM with propane 4HT burner
It made plenty hot water
But not as hot as my fuel burner that would "sustain" 270 ATM w/Ti wand triggered indefinitely
Once I got past my "heat freak" days of cooking valves and hoses prematurely, only used mega heat maybe 5% of the time .
Like on trashed loop com and too lazy to drag the rotary in
and joints with lots of gum (you can cook gum out at 240+)
Over half my jobs are cleaned with my diverter turned off, which gives me about 160atw.I dont think you'd say that if you'd used a fuel burner... the reason you've got a 650 is to imitate what every fuel burner does
I did go rogue and put the little giant with the ultraport. It would literally smoke the carpet. Never needed the Jimmy approval since I was doing cgd. That was a pita.Diesel HX direct drive or propane ?
well I was told back. In my ba-ne Clene daze that anything over 150 degrees and 150 psi would delaminate carpet and burn vans and houses to the ground
that man could sell ice cubes and air conditioners to eskimos...
or, in my case, a 23 year old brainless newb
He’s talking about Banes Jimmy the Leprechaun ....HISS!
I thought they were one and the same.He’s talking about Banes Jimmy the Leprechaun ....
Not Jimmy the Laundry troll
NopeI thought they were one and the same.
Enjoy burning those lines in today's poly carpet
Hot Turd!!
Been running Goodyear for 18 years runningYou a steel braid dope?
Veloceraptor steel braid hose currentlyYou a steel braid dope?
