Rug badger just wasn’t getting it out
further south than you
Thats what I meant. What pressure do you recommend on the 1st stage regulator? I set it at 65psi. I read it should be set at 70 but I tested it a little below that.
will depend on depth your going to, and how much reserve if any the compressor has. As long as you cant out breathe your regulator while exerting yourself
