Rug badger just wasn’t getting it out
hum on the way up (exhale)
Thats what I meant. What pressure do you recommend on the 1st stage regulator? I set it at 65psi. I read it should be set at 70 but I tested it a little below that. Seemed to work fine.
Hack Attack
Dan
only did one emergency ascent from 100 ft, weird feeling just blowing out and not running out of air in your lungs, all the while pooping yourself
  • Wow
Reactions: Nomad74
Hack Attack
Dan
will depend on depth your going to, and how much reserve if any the compressor has. As long as you cant out breathe your regulator while exerting yourself
