What's the number one rule when fixing brownouts?
I'm surprised at how many technicians and some owners that don't know this simple basic fact...
Treat it with a liquid browning treatment and groom it in. Do not rinse. Severe cases can be treated with browning treatment along with a tiny amount of neutral cleaner for lubrication and padded or bonneted in.
Meter Maid
The Undetective
Don’t use a high ph cleaner?
Come on, Mike, I respect your knowledge, and I’m still new, so tell me!
I find its always helpful not to cause it in the first place
but what you do, depends on if fixing someone elses mistake or water damage etc
Reactions: Ron K
Tell Governor Newsome to fire up Diablo Canyon nuke and flood the grid.
Haven’t had an issue in 7 years....
Why, as a professional, would a guy have problems with ‘brown out’...?
I run RO water... hasn’t been an issue since week 2...
Reactions: LCCFL
Meter Maid
The Undetective
What’s RO water?
I have an onboard water softener, if that matters.
What’s RO water?
reverse osmosis, removes 90-99% contaminants depending on system
water softener, removes positive charged ions replaces with sodium
deioniser, removes both positive and negatively charged ions
Reactions: Meter Maid
I didnt even think That would even be a step.
What's the rush to fix those particular issues?
Duh, the carpet needs to be dry.
Next day fix for a pissed customer is super common
Heck sometimes it's even the same day, just at the end of the day is it starts to brown out
How many annoying cleaners are never called back
Or... how many brown carpets are hiding the "out'....
It happens a lot
Very rarely, maybe never does browning happen on synthetic fabric. The so called “browning” effect is leftover cleaning solution dried
The real browning is rotting the fibers on natural fabrics and wool. Totally different process is needed to treat it
So the answer to your question on number one rule:
-Get off your lazy ass, leave the vibrating buffer orbot whatever, and browning treatment sprayer in your truck and pull out your hoses and do another cleaning to rinse out the remaining crap you left behind and leave a fan behind.
