- Oct 6, 2006
- 116,801
Wicking
“Wicking” is a term used to describe the upward migration of water-soluble materials on carpet fiber surfaces during drying. Wicking is a cause for recurring spots and stains by definition.
Carpet Cleaning, regardless of the method used, is not always effective at total soil removal. A certain amount of soil can be left behind at the base of yarns and on the carpet backing. Often, wicking is responsible for carrying soil from the base of yarns and backing materials to the yarn tips, where it becomes a visible problem.
Care tip:
If your carpet is experiencing Wicking after cleaning you can try these easy steps to fix the unsightly areas
-Let the carpet dry thoroughly for at least 48 hours
-Vacuum the area with a brush roll equipped upright vacuum, slowly and from three or more directions
-Lightly mist deionized water or 3% hydrogen peroxide on the affected area and gently blot with a microfiber (preferred) or white cotton towel. Look for soil transferring on to the towel.
-If effective, continue to lightly mist and blot, until the carpet’s appearance returns to normal
-Let the area dry and inspect
-If the carpet still does not look normal (keeping in mind that Wicking usually occurs in high traffic areas and wear may still be obvious) consult with your IICRC Certified Technician to set up a return visit or for suggestions on what cleaning solutions would be best for your carpet type.
Edits are welcomed
Care tip:
Edits are welcomed
