Help me name these glide parts
Heart of Dixie
Picture one:
1. Front return.
2. Back return.
Picture two: (is that notch the vacuum relief?)
1. Vacuum relief rise.
2. Vacuum relief run.
FB7777
Well..
if your intent is to not complicate things, then refer to them with the consistency of your current naming
1 back lip top
2 front lip top
encapman
St Petersburg, FL
Rick Gelinas
~ Front Edge
~ Back Edge
~ Channel bottom
~ Glide slots
~ Slot bridges
9 Edge notch
7 Orifice
Don't see why you'd need more than that. Keep it simple.
encapman
St Petersburg, FL
Rick Gelinas
Why not give the machinist a simple description, like the one I outlined above; and then let him tell you how he'd define all the various angles and radiuses. Meeting of the minds.
Ron K
Machinist are usually able to read a Blue print.
You can call it what ever you want. He should be able
to have a wand or jig there so he can understand....
slip fit...press fit... use a hammer.
God what are the tolerances for most wands?
plus or minus .015/.030 you can do that with a file.
I used to hold tolerances of plus or minus .00005
As I grow older, I'm more intolerant.
Mikey likey
Reactions: Ron K
