Orbot Vibe fixed
Well, My new pump arrived in the mail. I installed it and of course it didn't fit. I had to mount it vertical because it's longer than the original pump. I then had to get new fittings and hose to make it work. I hate hate hate those crush fittings and Ace Hardware didn't have any of the slip fittings. I can NEVER get those stupid crush fittings right. They always move and turn out off center. Then when I post pictures of my handy work, you guys get boners claiming water leaks that aren't there. Well after several times and going through three crush fittings, I said screw it and just man hammered it down. No leaks. If it does leak I'll get on the interweb and get a 3/8 MIP 90° elbow swivel with a 3/8 hose QD.
The new motor hangs down a bit, I need to be careful I don’t knock it into anything.
The new pump runs like a Damon to a Baconator. Just need to replace a couple more bolts and nuts and she's done.
403BB765-DA76-4729-B3CF-DB4D2A95455C.jpeg 24456FC8-5B52-4FC2-8372-0293410ECEF8.jpeg A3C89FE3-6A5D-452D-BEFE-9F3F1EC29277.jpeg
do you know what specs the pump/jets put out?
I've just not long got the redheaded stepchild of the OP world, running 60 psi 1gpm pump, 95:02 jets.. only used it twice on 2 small jobs
Here are the specs of the new pump and the jets.
The jets are two 6502 Unijet. The pump is a 115 volt 100 psi. The original was a 90 psi.
Reactions: Hack Attack
Rick J
Ohio
rick Jones
thanks, it looks like 02 jets is common
the 2 small jobs I did had cut pile and though it looked good I wasnt sure if was putting out enough juice
Well, not sure I like OP for cut pile, , maybe if short, and lightly soiled. did you use pads, or bonnets. If bonnets, could you tell how soiled they came up, and how wet when you changed,?
I got ahold of a Oreck a while back. Thinking I would use/try it on stairs , instead of my Stepson, when VLMing as many do. ended up just leaving/using at home, with 8 inch iron man pads under it. Heavy thick dense nylon. works well. easy and quick. Not sure I would claim to a custy that is deep clean.
further south than you
yeah was glued down cut pile in 2 reception areas, came up looking good
but was also using a different encap than normally and it has no foam, which also made me question my coverage?
Trip Moses
IMOL
Savannah GA
Trip Moses
Is that
Is that the HOS replacement option? Can’t be?
