- Oct 6, 2006
- 117,295
Let some Facebook guru have it.Replacement
Man, you're on point early in the morning!That’s extreme but not too far beyond what I deal with on a semi-regular basis.
1)Prevacuum thoroughly. (My vacuum would be cleaned and sanitized after.)
2) I would cover all the soiling possibilities with a prespray of Bio-8, D-Gas and PSor.
3) Rotovac my way into the room with a brush head.
4) Edge the room with a stand up filtration tool.
5) Wand my way out
Side note:
As I’m vacuuming, if I note any stains that I think may need dye stain remover and steam, I’ll do those before prespraying the carpet.
Jobs like this OFTEN require follow up cleaning and ALWAYS REQUIRE clarification of what can be expected.
Average cleaners will fail at these jobs because they won’t purchase the necessary equipment, don’t have the proper chems and are hesitant to price high enough to cover all the time necessary.
I can almost always clean these type jobs well enough to allow another rental season of use and save the home owner about half of the replacement costs.
I seldom encounter these jobs on owner-occupied houses.
so where do you find them?I seldom encounter these jobs on owner-occupied houses.
But there’s a reason you’re not cleaning anymore
I do work for property management companies and individual rental owners. Quite a bit of it. Anyone who does rental cleaning runs into this.so where do you find them?
military?
Ive only seen shit like that a handful of times., even with Millers and Coit
YOU have been around MIKEY far too long!and I still clean carpets
and can still clean better than the vast majority
and better than 67.893% with a POS porty and AW29 wand
Please re-read my above post a SECOND TIME!It's not BS when you can back it up
never used a RE except the RX-20.
The RE scrub in and wand out would be killer I'd expect.
I've always run 2 man crew, rotary scrubber is more efficient
(never had AT capacity to run two floor tools)
