- Feb 4, 2016
- 24,146
How many Mexicans does it take to screw in a light bulb? Just Juan.That’s my new bro-in-law’s name. Don’t offend me
Juan't think of it.That’s my new bro-in-law’s name. Don’t offend me
I've got 50k sitting in a TM account that I could spend tomorrow, but buying a hx unit aint gonna make me anymore money than a 15 yr old burnerI’m not saying propane is still practical, but people who run propane heated rigs aren’t refarted like Mikey says. They’re just broke dicks who can’t afford a heat exchange unit.
So? Also got spare kohler, blower and pump sitting in the garage so might be "Grand Dads axe" for awhile yetHack
Wth...even made you think of that?Shrinkage
Because you look like a penisWth...even made you think of that?
What's the madder wit you...anyways?
I'm rubberBecause you look like a penis
He’s guatamallenHow many Mexicans does it take to screw in a light bulb? Just Juan.
Chemtex. That van will probably go another 300,000 k.LETS BUY IT!
Truck mounted carpet cleaning | Trade Me Marketplace
2007 Toyota Toyace 296000km good condition, all the bells and whistles. External fuel tank petrol and Diesel, external hose reel, external dump, loading ramp...www.trademe.co.nz
Dunno what prespray he uses but it aint right
Trucks probably worth 30k but too big for most residential, and it's a TeXaN..Chemtex. That van will probably go another 300,000 k.
Not really a fan of box trucks in the city. I hear the chemtex don't have a great reputation but don't have any personal experience with them.Trucks probably worth 30k but too big for most residential, and it's a TeXaN..
I've got a chemtex... in partsNot really a fan of box trucks in the city. I hear the chemtex don't have a great reputation but don't have any personal experience with them.
too bad we can't just buy them off the shelf. They sound a lot better than the LG heaters. More guys would be tempted to use them.The propane heater that we use is totally automatic. You arrive at the job, set up, turn on the truckmount, flip one switch and the heater lights itself automatically. When you are done cleaning you turn the switch off and turn the truckmount off. Our LP heater is 240,000 BTU's and will supply insane heat to 2 wands while we are cleaning for a total of #12 flow rate. We have accounts at 2 local LP suppliers who do nothing but fill propane tanks with qualified employees. We can usually get 2 weeks of cleaning out of one fill. Both of these heaters are over 14 years old.
We have 2 of these heaters, one in each of our 2 dual wand vans.
You can buy these heaters from any PW supplier, but they only come with a flow switch. A flow switch only allows the heater to come on when the wand is keyed, and that is not enough burn time to get the heat up so it will stay there and be constant with no big spikes. I patented a circuit that goes inline so the burn, once activated by keying the wand, will burn for a range of 1 second to 25 seconds (adjustable), and you control the output temperature depending on where you set the temperature dial, either up or down. If anytime during that 25 seconds you key the wand again, the process starts all over again, ultimately controlled by the high limit thermostat. This eliminates any heat spikes or drops during the entire time you are cleaning. Like I said in my previous post, it will run 2 wands with no heat drops or spikes.too bad we can't just buy them off the shelf. They sound a lot better than the LG heaters. More guys would be tempted to use them.
sounds very similar to what was on my Duane mount, it would preheat I think for 90 seconds on startup, refire with waterflow and run for around 30 secs after letting the trigger go with a high and low range it stayed within..You can buy these heaters from any PW supplier, but they only come with a flow switch. A flow switch only allows the heater to come on when the wand is keyed, and that is not enough burn time to get the heat up so it will stay there and be constant with no big spikes. I patented a circuit that goes inline so the burn, once activated by keying the wand, will burn for a range of 1 second to 25 seconds (adjustable), and you control the output temperature depending on where you set the temperature dial, either up or down. If anytime during that 25 seconds you key the wand again, the process starts all over again, ultimately controlled by the high limit thermostat. This eliminates any heat spikes or drops during the entire time you are cleaning. Like I said in my previous post, it will run 2 wands with no heat drops or spikes.
I have been using these awesome heaters for 20 years!
At Winterfest ...Duane was most anxious to show me his machine andsounds very similar to what was on my Duane mount, it would preheat I think for 90 seconds on startup, refire with waterflow and run for around 30 secs after letting the trigger go with a high and low range it stayed within..
single wanding I didnt need what it put out, so swapped an LG in when my waterbox overflowed and fried its brain
Last I heard he was making reels.At Winterfest ...Duane was most anxious to show me his machine and
Hurried me out to look at it....
I did openly laugh at it....and I believe I may have hurt his feelings a bit.....
But it WAS the biggest POS I have ever seen!
Then I made the mistake of selling him a brand new Cat 500 pump which took over 6 months before I ever got paid ....wtf ever happened to him?
Reely?Last I heard he was making reels.
