- Oct 7, 2006
- 49,910
Yes, as the Border Patrol budget attests ...
If I were built like a STUMP, this would not be an issue for me.
It comes with a 12" hose before the valve for the quick connects. But, I prefer to have the 12' leader solution hose and drop the weight of the quick connects and the shutoff valve to the floor. It makes a real difference. Why should you hold up the weight of all that metal when it can just be on the floor and the top end of your wand can be that much lighter? It's really not a problem on the floor when covered with a quick connect wrap and the hose being super skinny it's like it's not even there.Kudos Dave.
I wonder about having to drag the disconnect around on the floor.
Does attaching the qc directly to the handle limit the available arc for adjustments?
Haven't heard much good about it.Is anybody using this handle? I'm thinking of giving it a try.
If he put his OTHER hand on the OTHER handle maybe.....but I can't see pushing the wand one armedIf it was worth it then it would have been knocked off by now
Exactly, just creates another.other than rotating, and "NASA" cushioned handle, the gunjet wand has been around since at least 1990 (I had one)
I question whether it will help the repetitive motion ailments wanding causes.
just puts some of the stress in a different spot is all
He jumps from Facebook group to Facebook group reinventing himself every time..Is Yoakum still around?
I hope he didn't run too many baths for naked kids to run in...
Good for him. Last I knew he had cancer and it didn't sound good.He jumps from Facebook group to Facebook group reinventing himself every time..
