New ergonomic wand handle.
Goomer
Cleaning Professional
Frank Mendo
Kudos Dave.
I wonder about having to drag the disconnect around on the floor.
Does attaching the qc directly to the handle limit the available arc for adjustments?
R
Royal Man
Kudos Dave.
It comes with a 12" hose before the valve for the quick connects. But, I prefer to have the 12' leader solution hose and drop the weight of the quick connects and the shutoff valve to the floor. It makes a real difference. Why should you hold up the weight of all that metal when it can just be on the floor and the top end of your wand can be that much lighter? It's really not a problem on the floor when covered with a quick connect wrap and the hose being super skinny it's like it's not even there.
You did get me thinking! Since I personally like to add the leader solution hose and the wrap so much. I'll do you guys a favor...
As an introductory offer I'll give away with every order a FREE 12' supper skinny solution line and a FREE quick connect wrap and a FREE Gear Tie to keep it all in place to store in your van.
www.ergowand.com
D Luke
Derek
Is anybody using this handle? I'm thinking of giving it a try.
bob vawter
Grassy Knoller
bob vawter
If it was worth it then it would have been knocked off by now
If he put his OTHER hand on the OTHER handle maybe.....but I can't see pushing the wand one armed
From that height.....jus sayin!
other than rotating, and "NASA" cushioned handle, the gunjet wand has been around since at least 1990 (I had one)
I question whether it will help the repetitive motion ailments wanding causes.
just puts some of the stress in a different spot is all
Reactions: Mike Pailliotet
Exactly, just creates another.
Try a 12" SSTi wand..or a helper.
I thought this thread was new, lol
Fred needs to make the date of the thread a little bigger
Reactions: Kenny Hayes
Zee
Is Yoakum still around?
I hope he didn't run too many baths for naked kids to run in...
:D
